Seems rather small and the kv is quite high- normally something larger than a regular inrunner would be used with a much lower kv, with the front & rear diffs being directly driven by the output shaft sticking through both ends of the motor. Linc & Sike are the outrunner gurus though, woudl be worth doign some digging and research into outrunner setups around here..
