RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.30.2011, 03:50 PM
I should be able to keep this version in stock - it is more "universal" than the previous version in that the bearing inserts are plastic and can be removed - a custom insert could allow a different bearing type, such as the losi flanged bearing. Also, with the inserts removed, a 19mm bearing should fit(didn't chase high tolerance, but it will be very close, as the hole is drawn at .75" and a 19mm bearing = .748"). The sliding upper plate also allows easy fitment of different length diffs by allowing the uprights to be spaced as needed.
