I used them and everything feels fine. I try to follow the instructions exactly so if there is a problem after that Mike will make it right. A lot of time went into developing this product. So I have to believe if the instructions tell you to do something then I do it. You might try to rebuild and this time try it with the o rings and I think it will work out better.
Good luck.
