pcnutz
pcnutz's Avatar
03.23.2006, 04:22 PM
I am not going to argue, but just to let other know if they come up with the same questions
mess can be cleaned quick with scotch bright
dry time is 24hrs if your changing pinions at track your screwed in first place
cheap decent thread lock all works
if you heat your motor to melt threadlock you done screwed up your motor 400 farehight
pinion puller will pull anything off your shaft without out screwing up rotors glued to shaft
pinion puller put absolutly no pressure on rotor magnets only on tip of shat and pinion
Dafni
Dafni's Avatar
03.23.2006, 05:08 PM
Oh okay. I didn't knew those pullers only push on the shaft.
Thank you
DAF
