Aussie Nerd
07.11.2011, 05:29 AM
Rear axle lockouts/tubes done (at this stage anyway). The gearcase might get some machining though.
Front axle tubes nearly complete. Just needs a set of HR 300s, I put the one in from my super, but I'll need to get a set for this. Also will just need to drill and tap when I settle on a caster angle for the C's. Again like the rear I might do some machining on the gearcase too.
Haven't had a chance to mock it up on the chassis yet, but it's very much on the agenda now the rear axles don't fall apart whenever you look in their direction
Kieren
