Hmm...look at all your connections really well. Motor to esc, battery to esc and make sure they are tight and not loose if they are bullets. If you have some resistance in the system somewhere it can cause stuttering/cogging.
That's the first place to look, if all seems well then I would try to swap with your MMM and see if the problem goes away. If it doesn't then I would say the motor might be suspect somehow.
