Came home from work and had three packages awaiting me.. One had one pair of badlands, another had the other pair, and the last one had the RPM revo hubs.
I'm still waiting for my big shipment from Rcplanet to come though...
Also, I had a bit of time to mount the front shocks...The rockers I have mounted are for the rear.. they will be replaced by the correct front long travel rockers once they come.
I wasn't planning on doing that till further on in the build.. but things started to get complicated fast..as I found that the only way to make the motor fit in between the front and rear shocks was to slide the center differential as far forward as I could. How far I could push the center differential forward depended on where the shocks where mounted..so I had to mount the shocks first then return to trying to design the lexan parts which will be sandwiched inbetween the top and bottom aluminum plates and will be where the TVP's are mounted to. The lexan parts will support the center differential so that's why it's taking me longer than I had expected to design and cut those parts. A picture of the complication...
*note the center differential be raised up and the skid plate bent upward to provide more ground clearance*
I'm crossing my fingers that tomarrow I will make large strides and be able to get the lexan chassis braces mentioned earlier mounted and also mount the center differential. (Something else I hadn't planned on doing before the chassis was completed)
Hang tight guys.
