cmac
cmac's Avatar
07.31.2011, 08:09 AM
Originally Posted by WEB View Post
That should be fine,you can put a Oring in each drive cup to take up the play or a slice of fuel tube it works to and then you are good to go??
Kept the good work going it would be looking like a truck now???
Not really yet. I'm still waiting for my new sheet of aluminum so I can make the ESC mounting plate (second try). The first one came out functional, but not perfect. I will try again. Does anyone know what size nut go on the end of the UE 6mm CVD's? My set did not come with the nuts.
