08.06.2011, 06:11 PM
Watts / volts = amps
volts x amps = watts
That is correct yeah. I would pay no attention to the listed ratings of the traxxas escs as those figures at total fantasy pretty much; most likely calculated by adding together the rating of each FET used, rather than using the rating of a single FET as the rating for the whoel esc ( A FET being the chip that controls current flow essentially ).
It would probably be easier to just see a link / brand & model# for the motors your buddy is looking at, would be alot easier to give a thumbs up or thumbs down without having to know any of the actual ratings as such as brand, dimensions & kv rating are more useful to know generally speaking to determine what setup it could be used in & with what esc & voltage etc.
