brian015
brian015's Avatar
08.11.2011, 09:02 AM
Originally Posted by CerberusVI View Post
Using the calculator I would need a 14t for 34.95 mph and it says motor rpm would be 44k. Granted 35 is plenty fast for bashing in my needs so 14t is the biggest I would probably go.
Diff ratio 3.308
Trans ration 1.701
54t spur
5.8" tires
6s 22.2v
Then I'd give the tacon a try - if you're looking for a cheap option, I think it fits your needs. (I also agree that the 1717 would be better if you could make it fit.)
