Originally Posted by 1truckerdan
The bore HAS to be dead center. Use a drill press!
the drill will follow the existing hole, right?
Was more concern about the hardness of the pinion than getting it 110% straight, guess i just gonna give it a try. dont have an drill press, and dont want to bug other to help me
if i sand the shaft down from 6mm to 5mm, i think there will be more risk about getting it straight than drilling the pinion. atleast its better to risk a pion than the shaft.
