Pdelcast
Pdelcast's Avatar
08.18.2011, 10:02 AM
Originally Posted by j.f.s View Post
They have less than 10 cycles on them.
Probably not a battery issue. Please be aware that the real lifetime of Lipos is about 200-300 cycles ... after that, ESC damage can slowly occur.
I just remembered something I forgot to mention in my initial post. I've changed the fan since the original one came apart. Fan was working now but is it possible that I've damaged the ESC with heat prior to changing the fan and this caused the ESC to fail?
Probably not -- the MMM has temperature protection, so if it gets too hot it will shut down.
Maybe it just had a weak capacitor, that decided to give it up...
In any case, contact our tech support and I'm sure they will be able to take care of you.
Thank you!
Patrick
Patrick del Castillo
President, Principle Engineer
