Just a thought: The input shaft of an EMaxx has a 13t hardened pinion. It's the 1st gear, the one that most folks here cut off anyway. Should be easy to get one, but drilling and threading a hole in it might be another story.
We should have some hardened pinions rather soon, actually. The stripped plastic spur may very well be a result of motor flex, though. If the gear mesh is set properly and doesn't change, the gears are pretty tough to strip. The hardened pinions will be pretty bulletproof, though.
Sorry for the late reply. The stripped plastic gear is my mistake. I thought it was a rather good idea to tape up the slot below the spur thinking thsat it will help sand from getting into the mesh. It had the opposite effect.
