Thanks for the help CMAC! I will be using the FLM center skid and chassis as well, so I will have to notch the chassis for sure.
Big thanks for the pic and the dimensions. I haven't ordered my center skid plate yet so when I get it I will make sure I am reading the dimensions properly.
So the slipperential comes with a couple drive cups (8mm, I believe). But are you using a couple of these (in 8mm size) to connect to the 13 tooth gear shaft for the center shafts/dogbones to fit into?
http://www.rc-monster.com/proddetail...RCM8mmdrivecup
