6606j
03.26.2006, 07:52 PM
Your idler shaft will be in the wrong spot. Could you drop your spur and pinion gears low enough to do the same ratio?
I'm just wondering about the gear ratio in the transmission because I know I can lower with the spur and pinion but wouldn't that be counter active to using the high gear in the tranny, I was just wondering how low you can gear on the spur and pinion, how tall a spur and how small a pinion can you get?
I 've been thinking about it, and I think I might keep both gears after all just in case in some crawling situations where you need more wheel speed and less torque
Torque won't be a problem, because I plan on using twin 65 T Lathe motors run off of the stock EVX but rewired for 7.2 Volts, instead of the 14.4v
