11.15.2011, 02:57 PM
You only need enough of the stabilizer to cover the teeth of the lowest gear, once it moves it will spread the stuff on all of the contact surfaces. Filling the case full would cause some serious drag issues!
As for it leaking past the bearings, the rubber sealed bearings seem to stop it, plus at rest you do not have enough product to fill the case up to the bearing lines.
The display in the auto parts stores is pretty cool. I always enjoy seeing the stabilizer stick to the gears.
