i need help with the double wire config. on the 12020 i received from you today. i've read all the posts about the same subject, but no cut and dry answer. the controller is going to a 1950, so 3.5 bullets wil be used. please help.:032:
right, but what is the best way to get the wire into the 3.5 bullet connector? cut one wire in each pair shorter, wrap it around the other wire and tin them together, then solder the one wire to the bullet?
The best way. Well, there really is no way to get two 4mm wires into a 3mm hole. I think the best way is to get one wire in and solder the other onto it as you described.
