Revorocks
01.20.2012, 12:47 PM
Anyone?
Found the bearings are 5x16x5mm
How do you replace them? I can get them out the end bell, but I can't get them out the cap...
E-Revo Brushless MMM + Neu 1515 5S
Hyper 7e MMM + Neu 1717 6S Speed Project
Pdelcast
Pdelcast's Avatar
01.20.2012, 01:54 PM
Originally Posted by Revorocks View Post
Anyone?
It sounds to me like something is dragging.
When you took it apart, might you have swapped the brass spacer bushings front to back?
Patrick del Castillo
President, Principle Engineer
Revorocks
01.20.2012, 05:10 PM
I put them back just as I took it apart. If I put them back the wrong way round would the shaft not be able to move back and forward a significant amount?
Took it apart again to check and the smaller length brass spacer is on the front (pinion side), the longer one is on the back.
Is this correct?
