magicald
01.25.2012, 08:26 PM
Your numbers are low(especially the Muggy). What sample rate are you logging data at? I have seen 200 amps on a 10 pounds truggy in testing with an average draw of less than 30 amps during the run. A low sample rate will mask the true peaks. Also, any punch control or expo settings on the radio can also lower the recorded peak draw.
The logging is set at default (I'll have to hook it up and check).
All other settings are at default... No punch control and radio is set on linear with no end points.
What's the best setting to change to tell if it's my batteries...if there is a setting?
