I supported the whole mount with motor and diff using 6 screws going through some holes in the TVP's and even used the rollbar screw as a support also, I tapped the 3mm plates for easy installation and dismantling. I like how low the motor is. The mesh adjustment moves the motor up and down, so as i gear up the motor has to be raised, buts its minimal. now installed with a 15mm pinion and 50 spur.
View of the rear, hoped by lipos would fit there. actually they don't.
View of the Front. The Motor actually clears the TVP's by a mm.
And please excuse the cleaning of the truck
and the crude cuts in alum
Was anxious getting everything together and testing. Will grind and file the pieces later on.
Also to mention the servo arm clears the motor; here the servo is at full swing. hoped i could swap the dogbones to move the motor more forward but they would get in the way of the servo arm.
