Thread Tools Rating: Thread Rating: 160 votes, 5.00 average. Display Modes
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
02.05.2012, 09:17 PM
Originally Posted by cmac View Post
I believe that the engineers have done a good job with this on road car. The use the aerodynamics to help pull the car down to the road. Like a wing only in the opposite direction. The on road car that you had obviously did not have that benefit. They use some similar principles like the Indy cars. If you could invert an Indy car at speed it would hold the road because of this effect. I heard that these cars are a little unstable under 50 mph that is about when the ground effects start to kick in after that it sucks down to the road and is stable as can be. I have a Losi 8ight that will run just like your buggy and it too is stable at around 70 mph, I have not had it to 100mph, but I bet it would be a whole lot different. I'm sure it would not be as stable.
1/8th scale wings are like open wheel F1/Cart/Indy cars. They produce mad amounts of downforce at the expense of high drag from the wing.
A 1/8th scale buggy at 100mph if it still had its original wing will be supremely stable. But it'll require a ton of power to reach 100mph, more than the XO-1 needs due to the massive drag the wing will generate.
Almost all of my old nitro cars that topped out around 55mph would gain another 5-7mph without the rear wing. With the rear wing at those speeds there was massive understeer.
Now fab up a mount and stick a 1/8th wing on the FRONT of your buggy too and it'll stick like glue to the road.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
