Ok, I have a lot the DTX 7 amp power supplies. If you want one I'll include it as well , but you'll have to use your diode in between of course because they spike up to 17 volts sometimes. This ps is one that hangs on the wall plug and has a wire that goes tot he charger. It would give you 2 seperate components , and a very clean set-up.
