video and painted body
othello
HV basher
video and painted body - 02.08.2012, 08:36 PM
Although the outside temperature showed minus 10°C (14°F) i had to give the chassis some rollout.
This is the video of its first test run
With this kind of driving i used around 100mAh per minute. Battery setup will change as soon as i'm 100% sure which lipos to use. As of now i think i can perfectly fit 2 5s turnigy 2200mAh (10s in series) below the top deck with lifting it a few mm.
I already painted the body and it came out pretty much as i wanted it to be ...
Right now my place is covered with snow and it's still too cold outside to conduct more test runs. But i will update this thread as soon as i'm able to get more test runs.
