Ok this has me puzzled.
Savage Flux with a Hobbywing 150A Esc Turnigy HV767 Servo and Spektrum RX, 4s Lipo set up. I hooked up the ESC to the receiver, with an extension lead with the red wire missing and then hooked up the BEC using one of these
http://www.hobbyking.com/hobbyking/s...r_adapter.html
between the Deans of the Lipo and ESC on one side. (ESC has dual Deans in a Series configuration like the Savage Flux Set Up does on the stock esc)
With the JST end plugged into the input wires of this BEC
http://www.hobbyking.com/hobbyking/s...ly_6_23v_.html
And the output connected to the Battery socket on my Spektrum Receiver.
Plugged everything in, RX has power, Servo moves fine, as soon as I turn on the ESC however, the wires between the BEC and Receiver melted as did the Servo Extension with the red wire missing between the ESC and RX
So I removed the adapter, extension and BEC, hooked up the ESC directly (using internal BEC obviously) and everything was fine.
....so what gives?
Any clues as I'm puzzled on this one!
