Rivermaxx
03.06.2012, 01:35 PM
Good luck with your setup. My official isc 2009 open wheel record 81.75 mph
with (g)e-maxx has been beaten by a buggy. I can tell you one thing all that power isnt really needed your probably better off with smaller motor spinning higher rpm. I was running a 2700kv neu motor on 6s gear for >120mph and had way too much power. I was breaking the foam tires loose around 75mph going through traps drifting sideways. Probably would of went faster on 5s. Hopfully those grp tires do better. Nic cas had a fairly stock schumaker with a special body on 3s with a castle mmm and high kv motor do ~ 130mph. Btw just got back on here becuse I wanted to convert a hyper7 I have into brushless for my son. Checking out you thread
