Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Ascender
Ascender's Avatar
03.11.2012, 04:08 AM
Wow, haven't been here in a while.
So, questions:
1. One of your original complaints about the Flux was that it was a "fat pig", yet you've actually made it a lot heavier by sticking the stock plates inside the TCS TVPs. As far as I know, NOBODY has ever managed to bend or break a TCS plate yet. Plus, the reason you had problems with the stock plates in the first place was that you removed all of the cross-bracing that makes the Savage line so strong when you took out the radio box and motor plate. Having the stock sandwiched in there is just pointless weight.
Second, you've missed the best proven handling improvements for the Savage, which are simply lowering the truck by means of an internal spacer in the shock, and getting an XL-length chassis. TCS makes a good one, or you can do like I did and order a set of XL-length carbon fiber TVPs from Platinum RC. They weigh less than the stock 2.5mm plates, and they're as strong or stronger than the TCS pieces.
Manne
05.16.2012, 01:35 PM
Very long time no see!
Will post some bash pics, and some video clips later on..... I have them just havenīt uploaded them ( I donīt have a youtube account yet...).
Ascender:
This is why it isnīt pointless to use the tcs chassis with the stock chassis: Look from 3.45 http://www.youtube.com/watch?v=09FbKPKRBvo
About the crossbraces, I bent the crap out of the truck in places where the braces didnīt do any difference. Like in the right rear section where the motor sits on a stock flux, in the thin section. My friend with a completly stock flux also bent the living crap out of it and he had all the stock braces, bent it in the same places as I did.
Thanks for the tip but I didnīt miss the XL length or the spacers in the shocks by mistake. I like high rideheight since I drive alot in rough gravelpits. And I like it short to easy make backflips and doing wheelies.
The main concerns that makes a stock flux "fat" is the crazy soft super sloppy sarvosaver spring, the thin shock oil combined with the stock mushy tires with non offset wheels.
I know that I have those big fat sloppy tires in most of the pictures, they soak up bad landings soo good so I like them for that, they also help alot to nail those tripple backflips. But I also use a set of crimefighters when I want it to feel more "racing", jump long and steady without backflips, turn good and drive fast.
Ola please be here somewhere, I want to hear about the Rc8t, still going strong?
Keep on bashing everyone.
