Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
Hot wires
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Hot wires - 03.23.2012, 03:19 PM
Hot wires could also be caused by other issues as well. Bad solder joint, lose connection, or maybe you have a nearly invisible short some place. Make youself a list of possible causes and go through your entire system one by one (simplest first) until you run into the likely culprit. Swapping out equipment may not always be the most viable solution, but it is the easiest way to eliminate components one by one as the problem. If you try another motor and things still heat up, than the motor is likely not your faulty link in the chain.
SUPERMAXX YOUR LIFE.
