Servo saver installed (excuse the messy wiring, i need to get a new receiver box as my last one was butchered by the previous owner... )
Rear end photos, showing Tripple A Racing High down force wing, RPM arms, Ramtech-RC Upper arms, Marks Beefy 9mm Dogbones, Hostile Axle Boots, Darksoul axle Tubes (hidden ;)) axle extenders, oh and i had to modify the gear cover to fit the pinion... it seems it is too wide for the stock cover... as it rubs, and i cant turn the pinion over as it goes too far into the mount... not that this should be a problem... some dust may get in but the gap is too small for stones to fit :)
My rear window, extends right down to the bottom of the roll cage, full protection from the elements for the esc :)
And finally, some overview pictures:
