Big House
Big House's Avatar
06.06.2012, 11:38 AM
I use a dremel metal cutoff wheel to make the big cuts and finish things up using the original parts as templates and the little drum sander to smooth all the edges. For the servo placements, I drill holes at each corner so I don't cut into the chassis. I set up my shop vac to catch the dust. I tried using a band saw but the cf just ate up the blades.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
