Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.10.2012, 08:12 PM
Next I tore down the 2spd tranny and found the idler gear pretty worn but with plenty left on it to last a while yet. I checked all bearings and bushings, cleaned everything and reapplied Mobil-1 Red Synthetic grease.
I then moved onto the original steering axle and drilled and tapped the broken
2mm screws and did a thorough cleaning and again used the Syn grease.
I bought 2 more steering axles from Rock @ RC4WD and tore them down as well and applied Syn grease during re-assembly.
http://store.rc4wd.com/Blackwell-X1-...le-_p_449.html
