rpm true track hubs
chrismechanic
rpm true track hubs - 06.28.2012, 06:48 AM
does anyone know if rpm true track rear arms cam be used with maximizer beadlock rims on my maxx???
and i keep breaking these new drive shafts....from the brushless edition e-maxx.
they wont do 6s .
i need to put my old cdv's back on but they dont fit the new hubs due to the larger bearing aaaarrrrgggghhhhh
chris
06.28.2012, 07:48 AM
Yes you can use maximizer beadlocks.
These cvd's will fit and aren't too expensive http://www.ebay.com/itm/Traxxas-E-Ma...ht_2624wt_1329
chrismechanic
06.28.2012, 08:02 AM
i dont think i will got for the shafts....i have several old sets...i might make up an adaptor so they will fit the new hubs.....
do the rpm hubs have the same size inner bearings ?
thanks
chris
06.28.2012, 09:34 AM
The outter and inner bearings are both larger on the RPM hubs:
http://www.rpmrcproducts.com/product...3.htm#trutrack
inner bearings are 12x21mm, outer are 6x15mm ( can't remember stock sizes ). The only cvds that will work are ones designed for the new emaxx models- stuff designed for the old 3906 emaxx won't work as it used inner & outer bearings that were the same size ( new emaxx shafts use totally different size inner and outer bearings and a different style of stub-axle ).
06.28.2012, 10:03 AM
^^ and that's why I pointed him to new shafts!
Besides the provision on the new shafts for 2 bearing sizes, they are different lengths. The old shafts just won't work.
chrismechanic
06.28.2012, 11:52 AM
ahhh i see...oh rubbish now i dont know what to do .
now i compare the old and new i see what you mean...the new has more length to it, the hubs are thicker on the new....the hole for the pin is further out...owwww that sucks.
that means making a complete new axle for my cvd's
im really thinking i should just go buy a new edition rolling chassis with no electrics....damn.
thanks as allways for your advice guys....
chris
lst 2 axle ?
mikesauto
mikesauto's Avatar
lst 2 axle ? - 06.28.2012, 12:42 PM
lst2 axles will work with mods and hold up nice I was bending old mip on 4s and 7" tires
chrismechanic
06.29.2012, 03:23 AM
thanks mike...yes they are old mip's
chris
