07.14.2012, 12:25 AM
Nope, the Rc-M revo adapter has an 8mm bore for 8mm pinion shafts.
What you would do if you want to use a revo shaft is simply get a set screw to use instead of the pin, or dremel the pin portion off.
But, if you are fabbing in a center diff dog bones and cups are the way to go. There are so many shafts available, you should be able to find a combination that works.
