I just purchased mikes losi 8 conversion, problem I'm having is the top bracket for the center diff doesn't fit properly, I could grind some off but being plastic not sure thats the best option. What does everone else do?
Can you post a pic? Did you reverse the diff from stock so the spur is on the motor mount side? I'm looking at mine and not sure why yours isn't fitting.
Well I did confirm with Mike it needs a little trimming, also when I search losi 8 conversions everyone that has come up with pictures uses some other type than the stock one.
