d3lap
09.01.2012, 10:51 PM
On my mbx5 the rear tire width is wider than the front deliberately. Running on bumpier plots I found it to be a tad bit more stable at higher speeds as well as it seems to corner a bit better
Yea im going to look into running wider rear's aswell. I've read that that the traxxas anacondas are great tires to use to bash around on-road, but they dont last super long. I guess its all about throttle input... Looks like my chassis is going to be about 333mm wheelbase.
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
09.01.2012, 11:48 PM
If you step that up to a 360mm wheelbase you could run Kyosho Inferno GT2 (360mm) bodies, or with a 400mm wheelbase you could run the DM-1, Hobao Hyper 1/7, or Traxxas XO-1 bodies.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
