Rc Monster Electric Conversion
10.07.2012, 08:04 AM
Its not needed the ESC and motor are not stressed under 60mph...
It just adds extra complexity - Unless you go fancy on brakes they are likely to overheat themselves.
Personally I direct wire the servo to the BEC and have the ESC power the RX. I makes it easier for connecting to the castle link.
Find all posts by Arct1k
2
10.07.2012, 02:40 PM
I run the hitec servo and motor brakes, NO bec and NO problems.
Find all posts by _paralyzed_
3
painter
10.07.2012, 02:44 PM
I think I may test without mechanical brake and see if it will be good.
You've tested so it should go fine.
And it's much easier to connect everything.
Thanks
painter
Find all posts by painter
4
10.07.2012, 03:02 PM
I also run a hitec servo off the esc, which makes things much simpler.
People have been running "HV" servos at 7.4v because 7.4 is a bigger number than 6.
A hitec servo at 6 volts is plenty strong enough to turn the wheels. People just like to brag about bigger numbers.
Hybrid Mode
Switch to Threaded Mode
