mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
10.17.2012, 11:47 AM
mistercrash, the only graph about 300 you are thinking about is cell level capacity vs. kWh throughput... so after 300kWh have been cycled through the cell, it is at 80% capacity. That is ALOT of energy throughput.
Yeah that's what I thought, I didn't understand the graph correctly
No brain, no headaches.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.20.2012, 12:43 PM
Dsch# 145
Cell IR reporting 1mOhm (cell temp 126F) CHARGE
DISCHARGE
Cell voltage: 3.447 (discharged a bit to get rid of top charge~99%)
Cell voltage under load: 3.089v. (after 30 secs of discharge
Discharge time: 1:57
zeropointbug
Z-Pinch racer
10.20.2012, 07:24 PM
Forgot to post the cell temp at start of discharge: 158F
Cell after discharge: ~170F
zeropointbug
Z-Pinch racer
10.21.2012, 08:11 PM
FROZEN CELL TEST
Cell temperature: -26 C (-14 F.)
Cell voltage before discharge @ -26 C: 3.456v
Discharge time: 1:56 secs (not 100% DOD, ~70% DOD)
Cell voltage with the 16ft of booster cable (6awg.): 2.02volts
Cell voltage at end of discharge: 2.86volts
Cell temp end discharge: ~10 C (50 F)
Quite a difference in start temp and end temp, at sub zero temperatures the cell is dissipating much more energy as heat... as you can see in the voltage drop.
zeropointbug
Z-Pinch racer
10.22.2012, 08:36 PM
Dsch#165 IR 2mOhm
4340mah
zeropointbug
Z-Pinch racer
10.23.2012, 11:50 AM
Any ideas for abusing this cell?
zeropointbug
Z-Pinch racer
10.25.2012, 02:46 PM
Well I'm at dsch # 200 and the cell reports up to 4360mah still and between 1-2mOhm according to 720i. If no one cares about this then let me know, otherwise I have no interest in cycling this thing.
A123 claims this thing can handle up to 10,000 cycles or ~280kwh energy throughput before it hits 80% of original capacity, I think that all we need to know, it's a tough little bastard, good for power cycling, but definitely not energy density, as it's only 70Wh/kg vs. 133Wh/kg for their 20Ah pouch cell.
This cell would be stellar as an engine starter battery.
