I figure some of you might like to see this little project I came up with to add a little BLING to the powerstroke shocks and get rid of some plastic. I decided to take pictures along the way to show the progress of how these were created.
Started out by doing a little drawing of the spring separator/retainer.
Then off to the old Enco lathe.
Grabbed some 1" bar stock that we had laying around the shop. I can use materials for myself as long as it is something that the shop can't use to make something with.
Drilled/bored the center and took it down to the largest diameter
Then took it down to the diameter that the upper spring sits in
Then started taking it down to the diameter that the lower spring sits in
