Looking for a 95-96mm dogbone?
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
Looking for a 95-96mm dogbone? - 01.26.2013, 03:24 PM
For my Hyper 1/7 conversion I'm reversing the center diff and would like to make sure there is enough room for a 85mm length motor (aka 1717).
I could run the existing 92mm (total length is 99m) dog bone if I use fuel tubing to act as bushings to center the dog bone between the front diff cup and the center diff cup. Just trying to see if there's a better fit.
The rear dogbone is already 160mm so its huge. I don't want to go much further back as the existing 92mm dogbone won't center properly and could cause issues.
Pin to Pin its about 92mm buy my micrometer. I'm guessing a 95 or 96mm pin to pin length would give me what i need.
Hyper 1/7 dogbone by thirdgen89gta, on Flickr
________________________
I found Kyosho PN# KYOIF143B, which is listed as a 95mm dogbone, but I don't know if thats total length or Pin to Pin. If total length it would be too short, as the Hyper 1/7's front dogbone is already 99mm total length. Looks kinda like it might not hold up to 1717 torque though with that weird step in the shaft.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
