rotary rocket
No Pistons
rotary rocket's Avatar
02.24.2013, 11:21 PM
Installed the battery trays. I decided to keep the weight balanced and as close to the center line of the truck as possible.
rotary rocket
No Pistons
02.24.2013, 11:23 PM
Motor went is with no issues. The mount is nice and beefy. Conversion came with a 12 tooth pinion and locked center diff. A regular diff is also in the works.
Check out the "back bone" brace. No flex what so ever.
rotary rocket
No Pistons
02.24.2013, 11:27 PM
Then came the ESC and the BEC. I also added the extra caps for good measure.
The kit came supplied with a sealed receiver box as well.
rotary rocket
No Pistons
02.24.2013, 11:28 PM
The kit also includes a new servo tray. Very well made and well thought out.
rotary rocket
No Pistons
02.24.2013, 11:29 PM
A side shot of the center diff spool, and housing.
rotary rocket
No Pistons
02.24.2013, 11:31 PM
Wiring buttoned up and batteries in place.
rotary rocket
No Pistons
02.24.2013, 11:33 PM
Plenty of room to work in with the customized cage installed.
