pinkpanda3310
pinkpanda3310's Avatar
03.15.2013, 11:52 PM
Originally Posted by mistercrash View Post
Once the charge is done, I checked the voltage of each cell with my Fluke and they all are below 4.205V so no over charging going on here. I did this for the first 5 charges just to find out if the chargers are consistant and they are. That is with the chargers adjusted to charge at 4.2V per cell. That is adjustable to a lower voltage if needed.
I think you missed what BrianG was saying. The final voltage will be reasonably accurate but when 3+ amps is charging through the tap that's when the cell could be over done. As the charger eases off at the end of the charge the resistance of the wire and connectors will have nil effect and the cell voltage can be read accurately.
I get it you like this charger and I'm not trying to speak out of turn, just seemed like a bit of misunderstanding
