SnoopMaxx
SnoopMaxx's Avatar
05.29.2013, 09:00 PM
Silver5 over at Traxxas forum mailed them and here's what he poster today
RPM emailed today saying that the new redesigned bulkheads are done and now in stock
I'd tell the guys at your hobby shop to get the first version replaced with the upgraded version
If I knew this when I bought mine, I'd have waited 'till now
On the front
You need to cut the triangle off of the back in the steering side
and use 3x20mm bolts for the chassis
On the back
the fin where you mount the tower, that lines up with the chassis
you need to trim that so it's flush with the chassis
and use 3x24mm bolts for the chassis
If you buy both front and rear, you only need four 3x25mm countersunk bolts
you can use the 3x20mm from the rear bulk on the front
Morten SnoopMaxx
Never to old to play
c",)
