speedy
06.26.2013, 03:05 AM
Hm.......?
So with if i set the current limitm to 80amps i won't get the same max rpm on the motor ? With low enough loadmon the motor so it doesn't need more than 80amps ?
The reason i whanted to limit the current draw are that because the motor will be powering a bushcutter or weedwacker and if the blade hits a stone or get's tangled in grass i don't what eanething to fry :). And the motor can put out 2300w more than i need.
