Wich hubs and axles are you using, to use those 1:5 scale tires?
Originally Posted by brian015
Alright - I cut 2" off the front of the chassis (still need to cut last bit off) and attached front end and wheels/tires to see how it looks. The wheelbase is 20"; rear width is 19.5"; front width is 19"
So I still need to install the steering assembly and front brace, make the front extended cvd, install esc/bec, and install roll cage and wing. But I'm beginning to think I'm going to be driving this thing this summer.
