Charging a battery for storage
nastety92
Charging a battery for storage - 12.18.2013, 12:18 PM
Good morning all,
I have a fairly new Hyperion 5s lipo that I purchased from Mike a few months ago. Now that it is winter here in Mass. I am putting my RC equipment away for the winter.
I'm wondering how I can put this battery into storage mode. Right now I'm using a MRC Superbrain 989 Charger. This charger does not have storage mode as a setting. I've read that storage mode should be around 60%. What is the best way to do this?
http://www.modelrectifier.com/search...ew.asp?ID=6863
Thanks,
Nick
Tamiya TRF801Xt-e
bdebde
That's All Folks!
bdebde's Avatar
12.18.2013, 04:20 PM
I think about 7.8 volts is what a storage charge does.
ta_man
12.20.2013, 09:24 PM
7.8V is for a 2S pack. For a 5S pack it would be about 19.5V.
To the original poster:
If the battery is already above 19.5V resting voltage, you should discharge it somewhat. I can't really think of any way for you to do that except running it in a car. I have my own techniques, but if all you've got is that MRC charger, they are not applicable.
If it is under 19.5, put it on the charger for a little while and take it off and measure the voltage. Repeat until you get to 19.5.
If you have room in your fridge, keep the pack in there over the winter (inside a plastic bag, with a dessicant pouch) and it will last longer. Don't charge it until it is back to room temperature.
