10.21.2014, 08:51 PM
From the looks of it, the bottom un-heatsunk PCB is the brains, so should generate little heat. I've seen lots of boards connected with pins like that, and as long as the case holds them together, there should be little concern even for off-road use.
And about the dual heatsink thing: FET packages are relatively poor at transferring heat, which is why they soldered the heatspreader to the PCB - which will pull heat from the FET faster than any HS on a plastic FET case. Then, they use the main large heatsink to dissipate the heat pulled from the heatspreaders. And even though the FETs on the underside of the PCB are not directly heatsinked, the large traces should be more than sufficient to transfer the heat upwards. IMO, not a bad design to be honest.
A better option to me would be to use FETs that have a low rdson and a high slew rate - those two factors alone can result in less heat to be generated in the first place. Those FETs have an rdson of ~3mohm and a rise/fall time of ~50ns. Not sure how those figures compare with FETs of other current generation ESCs, but that's something to look at.
ruudxd
10.23.2014, 04:07 AM
The Tekin RX8 has the 2 boards also connected by a row of pins.
I never had a problem with that and I assume that Tekin has done it's homework?
florianz
10.24.2014, 07:14 AM
hi,
where did you get the cap bank?
I think that its not a problem that the two layers are sticked together with pins, have seen that a couple of times.
Manufacturer should be sky rc, isn't it?
here some pics of mine, which has a different layout, dunno if the fets are the same
http://www.rc-monster.com/forum/show...465#post428465
