GriffinRU
04.08.2006, 04:20 PM
Well I was setting around and pulled out the 14L motor. I took a single aa battery and touched two wires on it. The rotor positioned itself. I turned it half a turn and did it again. It went back to the same position. I think this may be the best way to line them up. 1.2 volts is more than enough to align them up. Now I jsut need another nemisis motor 14L.
You still need to solder two motors together :)
Once you do that no batteries will require for matching...
Artur
