Pdelcast
Pdelcast's Avatar
06.30.2015, 03:59 PM
Originally Posted by ta_man View Post
Thank you!
Now a question:
The announcement mentions being able to use sensored motors with "purchase of an optional Sensor Harness from Castle Creations."
...and lists "X Series Sensor Harness" as part number 011-0108-00.
Does this mean the Monster X uses a non-standard sensor port and only a Castle X-series sensor harness can be used to connect to the sensor plug on a sensored motor?
The sensor harness is used to connect to a sensored motor that uses the JST sensor connector.
On the ESC itself, the sensors are part of the connector -- which is a standard 2mm header block.
There is not a "standard" sensor (JST style) on the main board. Just wasn't room for it once we added all those super-low RDS MOSFETs.
Patrick del Castillo
President, Principle Engineer
