maxxximatoze
12.13.2017, 05:30 AM
Ceramic bearings can make it both quieter and reduce IO -- but be careful, they damage easy. And the front bearing is especially easy to damage.
I can't comment on what MOSFETs we use. But you can probably read the numbers off the top of the chips if you are interested. :)
OK no problem ;) . Mamba monster X can be removed from it's plastic box ? I don't want to ruin my brand new esc just to see the mosfet ref...
Pdelcast
Pdelcast's Avatar
12.14.2017, 02:24 PM
Well, no. The heatsink would have to be removed to read the chips, and that would void any warranty.
Sorry.
Patrick del Castillo
President, Principle Engineer
maxxximatoze
12.14.2017, 06:57 PM
OK so I will NOT take that risk ! I will have to wait for it to burn... Is the monster X prone to self combustion ? :) Do you know a compatible motor mount for the Hpi apache/vorza to put the 1515 sensored in the chassis ?
maxxximatoze
12.20.2017, 05:13 AM
For info (and memory for me)
I have measured again I0, but this time with a higher motor temp (around 60°C) and the kv is rising up a little with temp (from 2220 to 2250) and I0 go down a little (-300mA from 4A to 3.7A@24V and from 3A to 2.7A@16V)
So the calculated max efficiency at 60°C of the motor is 93.7% for 16V and 91A (50W copper losses and 43W iron losses), and 94.0% at 24V and 131A (106W copper losses and 89W iron losses)
The esc+motor max efficiency is calculated to be around 90/91% for 16/24V
In fine, it's a pretty good motor with some high efficiency :)
I'm curious to see what would happen with hybrid ceramic bearing. I think I will do some tests later.
Pdelcast
Pdelcast's Avatar
01.08.2018, 02:44 PM
Ceramic bearing may decrease IO somewhat. But I wouldn't expect much of a difference.
When you compare our motor with others, you will notice our IO is very low, and efficiency higher.
maxxximatoze
09.10.2018, 10:18 AM
After a few months passed with this MMX/1515 sensored combo in my car, I can say that I'am prettu satisfied with the result until now. The combo is powerfull and reliable (2.02 firmware), but I have two question:
1) what is the ESC overheat temperature treshold (80°C ?) and what is the audible tone sequence to inform the user of this state ?
2) What is the over current limiter setting and why we cannot set it like with the XLX? it seems to be around 150/160 amps continuous (for at leat 4 seconds), because I can't get above this max value and the KV of the 1515, which is at 2220rpm/V no load, drops to 1700rpm/V which is a big difference with only about 5 mohms phase resistance (with turnigy graphene 10Ah 25C continous discharge measured with wayne giles IR meter V2) see graph below.
Thx !
Full size link: http://maxime.pierron79.free.fr/maxpowertest.png
Pdelcast
Pdelcast's Avatar
09.12.2018, 12:22 PM
Thx !
1. 120C is the preset shutdown temp.
2. The overcurrent is set to around 400A initially, and drops with temperature. But I have to explain that the "logged" current is an average, and the "limiting" current is a peak -- so they may differ considerably.
Thanks!
Patrick
