GriffinRU
04.18.2006, 04:10 PM
Originally Posted by cspurlock
I would be curious to speak with someone who actually has it working in a buggy and what type of running they are doing(bashing or racing). I tried several different gear ratio's and could not get it to stop from thermalling. I personally don't think it will work for racing, but if someone has done it, lets hear about it.
P.S. I did have the fan mounted.
With Kv=4400 forget about buggy conversion, unless you have 8 or less teeth pinion for 46t spur... or 66-72t spur with pinions you have :)
It is the motor which kills HV performance, wire HV-Novak ESC with good sensored motor (aveox...) and you will see BIG difference.
Artur
