Novak HV Maxx or Neo sphere -
04.22.2006, 10:05 PM
I have know nothing about brushless, and i never even thought about it till yestorday, so i have alot of questions. I have a rustler, but its all disasambled, and misssing parts, so i was going to pick one up cheap on ebay. I want to run it in the sand, but want it to have good torque, and speed. I eaither wan toget the Novak HV Maxx, or a LRP sphere neo stage 2. They are both around the same price to. The only reasion i would get the HV maxx is so i could run 14 cells. I also have a Tamiya horet, but i think a brushless motor would ruin all the gears. Will the Sphere neo have close to the proformanace as the HV Maxx? What speeds could expect from both? Which would have best torque? I just want a simple system, thats not to expencive, and goes fast.
04.22.2006, 10:08 PM
Also what are the lipo batterys? Are the better than the common mah(not sure about name)?
04.22.2006, 10:16 PM
Stick with the sphere the hornet will handle that. as for the speed it will be a handful. Lipos are a different makeup than nimh, it uses lithium instead of nickel.
I don't yet know as much about either as some others here so i'll let them elaborate.
Welcome to the forums and keep reading, every page will teach you something
04.22.2006, 10:34 PM
The hv maxx is made for a monster truck. It has gobs of torque. 14 cells is a lot of weight to run as well. I am not sure what your goals are. Some of the guys like the novak systems as well. Welcom to the forum to. The lipo is a lighter built battery pack. It retains it voltage bettery than the older nimh and nicads. It does have a few down falls. They are little more sensitve to what you do to them.
Peace!
Country
Help support the
Rc-Monster
Buy here
04.22.2006, 10:41 PM
Ive been reading alot of threads here, and people either hate the Novak HV Maxx, or love it. 95% hate it and about 5% of the threads i read. it might be just bacause the weight of the e-maxx. How fast will a rustler go with a neo stage 2, with 7 high quality cells? Could i safly run 8 cells in the neo? Safly meaning like without risking blowing it up?
04.22.2006, 10:48 PM
chances are 8 is a big no-no. im not sure about how fast it would be but the gtb 4.5 is another option if your looking for speed.
04.22.2006, 10:50 PM
I saw this video of a sand dragster, and it was a rustler, with a hacker system i think, and 12 cells. Heres the link http://www.rcrockgear.com/rbgerrish...rich320x240.wmv
If the link doesnt work try this http://www.rccrawler.com/forum/showt...t=30603&page=2
Its post #49
04.23.2006, 01:54 AM
I think i might just go with a sensoreless motor. Is this the esc that you can program for Acceleration, or top end or something like that. will i need anything else? And can i use the plane 4s lipos from towerhobbies.com? Are they really crapy because there cheap.
This is what i might get
MGM Compro 80 amp, 12 cell brushless car controller $185.00 $185.00
feigao5408s Feigao brushless motor 540 8s
Or could i go with this?
Nemesis
8,9 or 10L
36mm x 61mm 282 grams
6-12 cells* - 5mm motor shaft
Nemesis Blue Motor Specs Chart
Castle Barracuda 80 - 80 amps cont. 120 amps surge. 5-20 cells, waterproof, pistol grip compatible.
Hacker Master/Navy 70 - 70 amps cont. 7-16 cells, Waterproof, water-cooled and pistol grip compatible.
540 8L - Castle 80
540 9L - Castle 80
540 10L- Castle 80
540 8L - Hacker 70
540 9L - Hacker 70
540 10L- Hacker 70
All combos just 264.95 each!
Quantity
The only thing is the hacker esc is water cooled. And will a 8l be to much for a pede? It the Hacker esc programable?
Or this
Brushless High Power Electric Motors
Three motor sizes
540 S for 4-8 cells*
35.8mm dia x 51mm long
225 grams 1/8th shaft
540 L for 6-12 cells*
35.8mm dia x 60 long 282grams
5mm motor shaft.
540 XL 10 cells and up!*
35.8mm dia x 74mm long 372grams
5mm motor shaft.
Standard Features
50,000 rpm bearings!
Aluminum Purple Anodized Casing with 2-Pole Neo Magnets
& Compressed Windings
Feigao Motors
These are the same motors as the "Nemesis Blue" Motors being sold on other sites. Only ours are Purple.
Info on Feigao can be found here.
If your a sport boater or top notch racer on a budget, the Feigao motor is the Brushless motor for you! Feigao high performance brushless motors have the rpm and motor efficiency similar to that of Brushless motors that are Two times higher in Price! And for a limited time take advantage of our Combo Deals! We are packaging a high quality Castle Creations Control with a Motor for an even larger savings! At these prices you can get both the controller and motor for about the cost of a single competitors motor only!! Water cooling these is normally not necessary, but in extreme setups or racing Use Gundert 500 size motor jacket to cool the 540S series of motors and the 600 series water jackets to water cool the 540L and 540XL series motors.
Click here for Feigao Motor Chart
Example of Motor Description
Example motor: "540 7L 3,511 RPM per Volt"
540 is the Diameter of the Motor Housing
"7" stands for the number of turns
"L" Large - stands for the length of the Motor Housing
3,511 rpm per volt. RPM/volt x pack voltage = Total RPM
Only $69.99 for the "S" series Brushless motors. Good for approx 6-8 cells.*
1/8" shaft
35.8mm dia. x 51 long 225gr
540 7S 5,070 RPM per Volt*
540 8S 4,436 RPM per Volt*
540 12S 2,958 RPM per Volt*
Only $79.99 for the "L" series Brushless motors. Good for approx 6-12 cells.* 5mm shaft
35.8mm dia. x 60 long 282gr
540 7L 3,511 RPM per Volt*
540 8L 3,072 RPM per Volt*
540 9L 2,731 RPM per Volt*
540 10L 2,458 RPM per Volt*
Only $89.99 for the "XL" series Brushless motors. Good for about 10 cell and up.* 5mm shaft
35.8mm dia. x 74mm long 372gr
540 7XL 2,382 RPM per Volt*
540 8XL 2,084 RPM per Volt*
540 9XL 1,853 RPM per Volt*
540 10XL 1,668 RPM per Volt*
540 12XL 1,390 RPM per Volt*
540 13XL 1,283 RPM per Volt*
Brushless Motor and Control Combo Deals!
Castle Creations Barracuda 80 Marine Control
and Feigao Motor!
Click here for info on the Castle Creations Barracuda 80
Castle Creations 80 Barracuda Marine Control and Feigao Short (S)Brushless Motor!
Only $219.99
540 7S & Castle 80 Barracuda Control
540 8S & Castle 80 Barracuda Control
540 12S & Castle 80 Barracuda Control
Castle Creations 80 Barracuda Marine Control and Feigao Long (L)Brushless Motor!
Only $224.99
04.23.2006, 04:07 AM
I would not even think about using an L sized motor in your car, the S is more than enough.
For a speedcontroller, and the fact that you want to use Lipo, i would personally take the MGM controller, it is meant for car use. I ordered an MGM too, they seem to be as smooth as possible. plus they have the ability to be programmed to do a shut off when the lipo's voltage drops underneath the 3 volts per cell.
Your question about the Lipo-cells from towers.. what lipo's? got a link? The 8S can take quite some current from your lipo's. so you need a few good ones.
If you go for an 8S 4S lipo is just too much. 3S is insane on the 8S.
04.23.2006, 08:08 AM
Depends on how big of tire you got or going to run. alot of the guys like the 380 can size better than the 540 can size. I don't know cause I am newb at running the smaller stuff. You could go with a 12s with 4s lipo.
Peace!
Country
Help support the
Rc-Monster
Buy here
04.23.2006, 08:45 AM
Here is a link http://www2.towerhobbies.com/cgi-bin...po&FVPROFIL=++
Are liPo batterys more powerfull than the standard c size battery's or just alot lighter than c size so it makes them faster. There ment for planes right?
I read a post about the MGM not haveing good costmer service, and it gets fried alot.
04.23.2006, 09:58 AM
I am curious, where you find that thread, because here at rc-monster i haven't read anything negative about their products. It are the schulzes that are a concern in both meltdowns and customer service.
No, you can't say lipo's are more powerfull than standard C-size cells. It depends. They both come in all sorts and flavours.
With brushless you need the most powerfull batteries you can find. Lipo's are not meant for planes, they are meant for delivering much energy at a low weight.
With a lipo, you need to worry about the 3V cuttoff, otherwise the cell might be damaged.
When you want to use lipo for your truck, you need about 15-20C discharge rate and a capacity of about 3-4000 mAh
04.23.2006, 10:17 AM
Here is the post from the thread. I've used a Mtroniks Genesis Truck and a MGM Compro 12012.
Mtroniks - very smooth, WATERPROOF, great customer service (2 weeks total from California to England, no money paid except for shipping there). Reliability isn't bad, had only one go up in smoke. This controller doesn't seem to like external BECs, my XUS Hobby UBEC causes terribly stuttering/glitching on my Truck with the red wire removed from the receiver connector, but is perfectly fine using the built-in BEC.
MGM - very smooth, brakes that do weird (bad) things for racing/track running, not so good customer service. Sent in my damaged (I think from water) 12012, and repair took 6 months, during which time none of my 10+ emails were responded to (from multiple email addresses, including from Mike). So far on my replacement the BEC has blown out on 4s Lipo (it's visible on the shrink wrap), whereas my Mtroniks Truck is perfectly fine (so far) using the built-in BEC on 4s Lipo.
04.23.2006, 12:23 PM
I guess now im definatly going brushless now, because i also have a duratrax delphi indi car, and the stock tires have no grip to i put some hornet tires on it, and it griped relly nice, i put the GPS on it today, and it went 35.2, on a wet rode. I put a $20 13t motor in it. I was going for a nother pass, and i was 1/2 down the rode, and it just costed to a stop. I figured i was done anyway so looked at the GPS, and saw the speed, then whent to unplug the battery, and it nearly burnt my finger off. Then i covered my hands fith me swet shirt, and i pulled preety hard, and it wouldnt come apart. I walked home, and sniped the batters wires with plyers, and the last esc i have is trash, but what about my battery? Its a really good 6 cell battery that i only charged 4-5 times, so i better not be fried. Im 13 so i cant get a job till im 14, so its hard to make money, but if i sell my rc boat, and gravedigger tuber, i can get $580. I dont know what i should do. I really want to start saving up for a real car when i get my driving license (70 Nova), but im going to have to get a brushless sooner or later, so i might just order it today. I have $400 that i wanted to save. I was going to ask for the brushless for my birthday (May 28), i might ask for a aluminum pede chassis. But where can i get a crapy used rustler with no electronics, for around $50?
04.23.2006, 12:32 PM
If you had a tamiya connector on it. The connector may have failed. It not connection the esc can't work.
Peace!
Country
Help support the
Rc-Monster
Buy here
